Sweep not working
Sweep not working
onlrendelek
Sweep not working
onlrendelek
Hello!
I am trying to create a sword blade.
I made the outer shape in sketch, then extruded it. Then I want to make the edge (blunt edge) with sweep (in cut mode)
For the profile I want to use skecth4. For the path I want to use sketch5. The orientation would be: follow the path.
Why it does not working? I know there can be other solutions, but I want to use the sweep, and understand why it's not working.
Thank you in advance!
Erik
Sweep cause a self intersection.
kacper.suchomski
Hi
On the video you can see how the Sweep geometry solid behaves around the apex.
That's why you get a message about self-intersecting geometry (it's worth reading the messages - they often describe the problem in detail).
You need to change the modeling method or add an internal path to guide the profile.
Kacper Suchomski
onlrendelek
Thank you!
