Multi part/level process experiences
bradeneuropeArthur
Mentor Mentor
Message 1 of 10
bradeneuropeArthur
Are you using this method I reference to?
multi-part-level-process-skeletal-method
In special the "Multi Part/Level Process".
And what are your experiences with this method?
Or are you using simple skeketal modelling techniques like Multibody Design or equal.
Arthur Knoors
Programming Examples:
Drawing List!|
Toggle Drawing Sheet!|
Workplane Resize!|
Drawing View Locker!|
Multi Sheet to Mono Sheet!|
Drawing Weld Symbols!|
Drawing View Label Align!|
Open From Balloon!|
Model State Lock!
Posts and Ideas:
My Ideas|
Dimension Component!|
Partlist Export!|
Derive I-properties!|
Vault Prompts Via API!|
Vault Handbook/Manual!|
Drawing Toggle Sheets!|
Vault Defer Update!
Replies (9)
Message 2 of 10
johnsonshiue
Hi Arthur,
I suggest you watch the following AU online class, "All the skeletons in the closet- Skeletal Modeling Master Class."
https://www.autodesk.com/autodesk-university/class/All-skeletons-closet-Skeletal-Modeling-Master-Cla...
The technique the speakers used in the class allows them to build million-component assemblies in Inventor.
Many thanks!
Software Test Engineer
Message 3 of 10
bradeneuropeArthur
Thank you @johnsonshiue,
This is not using or explaining the "Multi part/level process" method.
Very high level of programming in this case, respect!
Still appreciate the link you have given me, thanks for that.
Arthur Knoors
Drawing List!|
Workplane Resize!|
Open From Balloon!|
Model State Lock!
Posts and Ideas:
My Ideas|
Partlist Export!|
Vault Defer Update!
Message 4 of 10
Frederick_Law
I don't do it this way.
I do use a Master Assembly to get "reference" from "referenced" or "purchased" or "customer" parts.
"Referenced Parts" -> "Master Assembly" -> "Master Sketch" -> Everything else
Message 5 of 10
bradeneuropeArthur
@Frederick_Law
Have you tried the multi level process, or don't you have experience with it?
Regard,
Arthur Knoors
Drawing List!|
Workplane Resize!|
Open From Balloon!|
Model State Lock!
Posts and Ideas:
My Ideas|
Partlist Export!|
Vault Defer Update!
Message 6 of 10
Frederick_Law
I need to read through it to see how exactly its done.
I don't think I've done it.  I only Project from sketch.  Always avoid part to part unless necessary.
And when I need, I put the part in Master Assembly, Project into Master Sketch before I use it.
I avoid that adaptive icon as much as possible.
Message 7 of 10
bradeneuropeArthur
@Frederick_Law
Do I understand correct that you use this without derive?
Arthur Knoors
Drawing List!|
Workplane Resize!|
Open From Balloon!|
Model State Lock!
Posts and Ideas:
My Ideas|
Partlist Export!|
Vault Defer Update!
Message 8 of 10
Frederick_Law
The Multi-part one doesn't have Derive.
It maybe similar to SSP in Solidworks.
Message 9 of 10
bradeneuropeArthur
Means project geometry and without adaptivity? This is disabled manually?
Arthur Knoors
Drawing List!|
Workplane Resize!|
Open From Balloon!|
Model State Lock!
Posts and Ideas:
My Ideas|
Partlist Export!|
Vault Defer Update!
Message 10 of 10
Frederick_Law
Don't know.  Not clear from the diagram.
Need to watch video, later.
