- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
- Report
We are in the process of changing our folder structure, but would like to do it without losing all of the part references in the assemblies that use the parts. I am finding that when I move parts into a sub folder, the assembly loses the referenced parts and must be re-linked. We have a LOT of assemblies, with a lot of parts, and would prefer not to re-link everything.
Below is an example of our folder structure and what I am trying to do:
Assembly (.iam) file is in the following location:
F:\STUFF\ORDERS\P02A426
Parts (.ipt) are in the following location:
F:\STUFF\FABRICATED
Location we need to move the parts to:
F:\STUFF\FABRICATED\MODIFIED
I was under the impression that Inventor searches subfolders for missing files, yet in this case it doesn't happen. when the .ipt files are moved to the new sub folder, the .iam file ceases to to find it. It's important to note, this department uses the "Default" project for everything. This project's search path is set to "F:\" and it works fine under normal circumstances, until a file gets moved. I have attempted to create a new project file that directs to the whole "STUFF" drive, but when I open my test assembly Inventor stops responding.
Can somebody inform me how to properly do this? Thank you.
