Edit View File
Edit View File
Ed__Jobe
Mentor Mentor
Edit View File
Ed__Jobe
I have several parts that are similar. I want to copy the ipt and dwg files and then edit the ipt files to create new parts. The trouble is that in the base view of the dwg, I can't change the ipt file that the view points to. It's greyed out. Is there a way to change it so I don't loose all my annotation because I have to start with a new view?
Ed
How to post your code.
SharkDesign
I think you have a part A and drawing.
You want to edit A to be B, but still use the same drawing (with a new name)
Have you tried:
Edit part A and save as B.
Save drawing as B.
Click 'replace model reference' on the ribbon bar.
Switch A for B.
  Inventor Certified Professional
Ed__Jobe
That's what I needed. Thanks.
Ed
