Most Efficient Way To create this iPart?
Alexrose1942
Message 1 of 16
Alexrose1942
https://youtu.be/uj34xfNFbkI
any ideas?  i don't know where to start? seems different then other extruded shapes ..
Replies (15)
Message 2 of 16
Alexrose1942
i was able to create a parametric model of this tray and make the ipart, the problem seems with publishing this to content center and use it as a frame member. im unable to author this correctly, seems like inventor take only one rod as the profile, although they are all extruded in the same feature also make this cat weird like changing the orientation of some rods after Author Command . generally i want to use this in the Frame Generator EnvironmentTray.PNG
Message 3 of 16
Alexrose1942
Anyone?
Message 4 of 16
I'll through together something. You in IV 2016?
Message 5 of 16
Alexrose1942
Message 6 of 16
So since you're in 2015, you won't be able to open my part file. I did, however, go ahead and make a screencast.
Now that I'm looking at it though, you seem to have more of an issue with publishing your part rather than actually just making the iPart.
Still, I made a screencast showing how I would create this part (first time around anyway) and after re-reading your post, I went to publish it and was able to do so succesfully. Even tried it out through FG and it worked just fine.
Let me know if this helps. Also, if you're still having issues publishing, I can publish this part again and record if you think that would help.
Message 7 of 16
Alexrose1942
i will try to follow and let you know, although ipart is ready but don't know whats wrong ,(see the file attached)
Message 8 of 16
Alexrose1942
ok! followed your steps, im almost there.Smiley Wink
can you author the part and make a screencast of it?
Message 9 of 16
Sorry I never got around to replying to this post Alex.
Did you manage to publish your part file?
I haven't been on the forums in quite a long time now. I came here with a question to post and saw the PM you sent me. Sorry about the very extended delay.
Message 10 of 16
Alexrose1942
@Anonymous Yes i got it working after a little play, actually now i forget what i did.. but it's there on content center
Message 11 of 16
@Alexrose1942 well good! I'm glad to hear it.
I would have felt pretty bad if I just never got back to this thread and you weren't able to do what you were trying to do.
Fortunately, for most things Inventor related, there are several resources out there for answering questions. Even though these forums still remain one of the best ones if you ask me.
Take care Alex.
Message 12 of 16
Can you provide a video on how to publish this part into the Content Center?  Creating the part video was very helpful, I am just having difficulty publishing.
Message 13 of 16
johnsonshiue
Hi! There are quite a few videos on Youtube and Autodesk Knowledge Network. Please google the following terms.
Autodesk Inventor Publish iPart to Content Center
It is very straightforward. If you still have issues, please share the iPart factory file here so forum experts can take a look.
Many thanks!
Software Test Engineer
Message 14 of 16
I need some help, I have created a wire basket cable tray and converted to an iPart.  The iPart works correctly, but when I go to author it under Structural Shapes I get an failure notice for reasons unknown.  I followed instructions on how to create the part (from this forum  - message #6) but I'm note sure how to author and publish this part.
Also, it was suggested to me that I look on YouTube to find a video on how to do this, unfortunately I have had no luck.
I would like to use this in Frame Generator.
https://forums.autodesk.com/t5/inventor-forum/most-efficient-way-to-create-this-ipart/td-p/6019292
Message 15 of 16
Mark.Lancaster
@Anonymous
Make sure to post only once https://forums.autodesk.com/t5/inventor-forum/authoring-a-structural-shape-that-contains-multiple-features/td-p/9180597 about a given issue and not in different location.   Posting mutiple times about the same issue leads to mutiple conversations that could pull you in different directions..  😁
Mark Lancaster
Message 16 of 16
johnsonshiue
Hi! This is a duplicate thread. Please see the reply to the following thread.
https://forums.autodesk.com/t5/inventor-forum/authoring-a-structural-shape-that-contains-multiple-fe...
