Modified border does not update
vex
vex
While attempting to update a modified border to bring into agreement with established borders of various drawings I've run in to an interesting problem:
Trying to increase text height in definition does not reflect alterations when placed in the drawing.
shows up like this (as it should) in the editer view
Which shows up like this (which it shouldn't) when I save and exit out of the border edit tool
Notice it has undone the size changes to the horizontal zones. Is there any fix? I've tried for about an hour to fix this issue with no luck.
Mark.Lancaster
I could be wrong and thinking of something else..   But I thought I ran across this issue before and it had to deal with the text (the numbers) being patterned in the border definition.   But I could be wrong... Smiley Indifferent
Mark Lancaster
vex
I thought that might be the case as well, but unfortunately it appears the numbers are not patterened. To add an additional head scratcher to the problem: the bottom set of numbers can be altered as necessary, however as soon as any number on the top is modified it reverts all numbers back to the original text type....
Mark.Lancaster
I had to do a little digging but...
The zone border lettering is associated to the pattern that is created for the zone border lines. When you go to modify certain zone lettering (like #1) and exit editing text… The lettering size will not update and Inventor recreates the pattern causing the other zone letters to resize as well. To correct this you can do one of the following:
1. Delete the existing zone border lettering and create your own that is not associated to the border line pattern.
2. Define a zone border text style with the appropriate size text font and then create a new zone border using the updated text style.
Mark Lancaster
Paul-Mason
The zonal letter/number size, colour and font are controled in the STYLES EDITOR.
I found it quite esay to add a text named BORDER and assign that to the bored in OBJECT DEFAULTS
1 Cerat anew text name
2 Set it to BORDE in OBJECT DEFAULTS
Inventor 2027 Pro
HP Z4 G4 workstation
Xeon Processor Intel(R) Core(TM) i9-9920X CPU @ 3.50GHz (3.50 GHz)
Memory 128 GB (128 GB usable)
Graphics Card NVIDIA Quadro P4000 (8 GB)
Ashington Northumberland (UK) ~ Home to the WORLD FAMOUS Pitman Painters Group and myself
vex
Thanks for that! I orignally attemtped to do 1. but the error persisted because I would re-associate to the border pattern. I have since fixed it this way. I will now have to figure out the iRule for automatically updating the numbers on subsequent sheets... :3
