Inventor Forum
Modelling Help - Eliptical Lozenge
5 REPLIES 5
110_turner
457 Views, 5 Replies
Hi
I have tried this a number of times and am not getting anywhere close
Eliptical in plan view
Semi Eliptical in cross section through both axis
Flat plane bottom
Im sure there is a way - Just having a senior moment - well continuosly last couple of months rally.
any pointers would be appreciated
regards
David
kelly.young has embedded your image for clarity.
5 REPLIES 5
subhashmecha
in reply to: 110_turner
Hello David,
Couldn't able to get your question. what you are trying to achieve ?
Are you trying to assemble two different part files?
Thank you,
Subhash.
WHolzwarth
Perhaps this way does it (2016 IPT in attachment)
Walter Holzwarth
kelly.young
Hello @110_turner if you can attach the attempt of your Part so forum experts can give you detailed advice that would be helpful.
Also be sure to indicate the version year you are using to ensure you can open any attached files.
Attached is a 2017 attempt, drag the EOP up in the Model Browser (red X End of Part) to inspect the modeling technique.
@WHolzwarth nice use of Direct Edit!
Please select the Accept as Solution button if a post solves your issue or answers your question.
110_turner
in reply to: kelly.young
Thankyou
That works for me
regards
David
110_turner
in reply to: WHolzwarth
Thankyou
That works for me
regards
David
