Modeling Help
Modeling Help
Modeling Help
Hi all, I'm quite new to inventor (come from 20 years ProE!!) so I am in need of some help.
I am trying to model a bayonet style fitting and am struggling to think of how to model this feature:-
Can anyone please advise of the best way, I am assuming some kind of sweep though unsure of how to achive this in inventor
WHolzwarth
IMO, best way for doing these Pin-in-slot tasks is thickening of a mid-surface. 2014 file attached.
Walter
Later: End fillet is changed now
Walter Holzwarth
PaulMunford
You could model the negative as a new body and do a boolean cut?
Customer Adoption Specialist: Autodesk Informed Design
Help | Learn | Forum | Blog | Ideas | Sample content | Linkedin
hncarle
You could also sketch on say a plane, xy or whatever and extrude cut it out.
WHolzwarth
This can be done, if tolerances are big enough.
But for a tight fit between pin and slot, thickeniing of a mid surface is the best way.
Walter Holzwarth
