Hex Nut Chamfer
Hex Nut Chamfer
chris90
Hex Nut Chamfer
chris90
This has absolutly nothing to do with Inventor, but I have found no answers elsewhere...
What is the purpose of the 30 degree chamfer on hex nuts?  I've been told it's to help a wrench drop on.  I've also been told that if the chamfer is not machined on the the side contacting the metal/washer, the nut will tend to loosen faster then if it had the chamfer.
Any of this make sense?  Is there a source out there for this inane kind of data???
blair
The top side wrench/socket drop sounds plausible. The underside I was told reduces any galling when the nut is tightened. The same with flat washers, there is a correct mating side with the bolt.
If you look carefully, the top side of a flat washer has a small radius from the stamping process. This should mate with the bolt head to help reduce any scoring of the root of the bolt shaft and bolt head.
Inventor 2020, In-Cad, Simulation Mechanical
Just insert the picture rather than attaching it as a file
Delta Tau Chi ΔΤΧ
