Force Effect - Applet Loading Hang
blair
Mentor Mentor
blair
Which applet does Force Effect call for on it's first run instance. My version of AVG blocked it and now Force Effect hangs. I have a request for support into AVG, it would be nice to know which files are being called for to solve this issue.
thanks,
Inventor 2020, In-Cad, Simulation Mechanical
Just insert the picture rather than attaching it as a file
Delta Tau Chi ΔΤΧ
mercerc
Force Effect calles for C:\Program Files\Autodesk\Inventor 2016\Bin\ForceEffectAddIn.dll
You may also want to check to see that you have access to the Autodesk.com website as it may make a call there also.
Charlie M
Inventor Product Support Specialist
blair
Thanks, I fixed the issue last night. Had to un-install R2, disable the Anti-Virus and reinstall R2. Then run the Force Effect to pull down the plug-in. Reactivate the Anti-Virus software which solved the problem.
Works fine now.
Delta Tau Chi ΔΤΧ
