Inventor Forum
Model space not displaying correctly.
9 REPLIES 9
Message 1 of 10
10741981
357 Views, 9 Replies
Inventor seems to be running fine but when I try to start a new part, assembly, drawing etc. I get a blank screen where the 3D planes should be showing. When I try to create a sketch an icon appears in the modelling space and there is nothing to highlight/select.
I have attached some screen captures to help visualise what I mean.
Why is this happening & is there a fix for this?
Thanks in advance.
9 REPLIES 9
Message 2 of 10
JDMather
in reply to: 10741981
@10741981
Have you installed all Updates for your version of Inventor?
What happens if you turn on the Visibility of the planes?
What are your View Tab > Object Visibility settings?
Can you Attach a file here that exhibits unexpected behavior?
Message 3 of 10
Gabriel_Watson
Possibly corrupted files/templates:
https://www.autodesk.com/support/technical/article/caas/sfdcarticles/sfdcarticles/Origin-planes-and-...
Always try installing the latest updates, if you are using the latest version/year (with very few exceptions).
Message 4 of 10
10741981
in reply to: JDMather
Hi There @JDMather ,
I have installed all updates for Inventor via 'Autodesk Access'.
Turning the visibility of the planes on & off doesn't do anything, still showing the model space as blank.
Everything is ticked in the View Tab > Object Visibility settings.
What type of file would you like me to attach?
Many Thanks,
Message 5 of 10
10741981
in reply to: Gabriel_Watson
Hi There @Gabriel_Watson ,
I have installed all updates for Inventor but still no luck.
Having a look at the link you attached, the pictures do look somewhat similar to what I am experiencing.
I can see that it is currently being investigated though, so i'm assuming no fix yet?
Many Thanks,
Message 6 of 10
JDMather
*.ipt file that exhibits this behavior on your machine..
Message 7 of 10
10741981
@JDMather
Please see below the attached file, I have also attached a photo of how it appears on my screen.
Message 8 of 10
Gabriel_Watson
Your file behaves normally here. Most likely you should re-install Inventor and try again.
Message 9 of 10
10741981
@Gabriel_Watson, I had a feeling it would, which was why I wanted to attach a photo of how it appears on my laptop. I have un-installed and re-installed Inventor multiple times but it appears to have changed nothing unfortunately.
Message 10 of 10
johnsonshiue
Hi! When you pre-select a plane or planar face, the origin planes will not show up. Also if one of the origin planes is invisible, the three origin planes will not show up when starting a new sketch.
Many thanks!
Software Test Engineer
Technology Administrators
