Inventor Forum
Model Representation Position
4 REPLIES 4
Iain_WilsonNNW35
297 Views, 4 Replies
Iain_WilsonNNW35
I've got a model with multiple representation positions that I would like to present to a client with the ability to switch between them easily.  Currently I send out singular position models that can be viewed using Autodesk viewer by clients.
In the future I would like to do this with an assembly with multiple representation positions, However in Autodesk viewer which I currently use I can't see the ability to switch positions.
Does anyone know if its possible to do this either in Viewer or another program?
4 REPLIES 4
kacper.suchomski
Hi
Here another user mentioned the need for Model States in Autodesk Viewer. I think it's a good idea and worth publishing on Idea Station.
https://forums.autodesk.com/t5/inventor-forum/model-states-in-shared-views-autodesk-viewer/td-p/1239...
If your idea is different and refers to broader functionality, you can submit your own idea and describe your expectations in detail.
Kacper Suchomski
YouTube - Inventor tutorials | WWW | LinkedIn | Instagram
Hi
Kacper Suchomski
johnsonshiue
Hi Ian,
Another way to do that is to export the Inventor assembly to DWF (Complete option). The Design View Rep and Positional View Rep will be exported accordingly. Your partner can simply install Autodesk Design Review (free viewer) to view the assembly without having to install Inventor. Yet another way is to install Inventor ReadOnly mode.
Many thanks!
Software Test Engineer
Hi Ian,
Many thanks!
Iain_WilsonNNW35
Hi Johnson,
I've tried your method with the DWF format with my test assembly and while I can view it, I still cannot see any options for viewing the different representations in the viewer.
Iain
Hi Johnson,
Iain
johnsonshiue
Hi! If you use "Complete" option when exporting, expand Publish Views node in the Views browser on the left. You will see the Design View Reps and Positional Reps.
Many thanks!
Many thanks!
