Inventor Forum
MODEL ORIENTATION AFFECTS DRAWING DIMENSIONS
3 REPLIES 3
AIR_123
197 Views, 3 Replies
Guys,
I have issue with drawing dimensions.
I have part which has specific orientation is space. I'm making drawing out of it using custom view orientation.
It seems if model projected in custom view, IV does not understand this projection on the drawing and cannot project dimensions same way. Any way to fix this?
Front view of the pipe
Top view of the pipe
Pipe top view custom projection
Dimension is placed respecting original orientation, but not the custom one.
3 REPLIES 3
JDMather
in reply to: AIR_123
You did not show screenshots of setting for True Dimension or Projected Dimensions.
Can you Attach your files here?
AIR_123
in reply to: JDMather
@JDMather where is that setting, I'm not aware of it.
Sorry models cannot be shared.
AIR_123
@JDMather
I think you mean this setting. This worked. Thanks for a tip.
Confusing that IV by default would not switch to projected dimensions, since its obvious if I did custom projected view, dimensions should follow.
Technology Administrators
