Guys,
I have issue with drawing dimensions.
I have part which has specific orientation is space. I'm making drawing out of it using custom view orientation.
It seems if model projected in custom view, IV does not understand this projection on the drawing and cannot project dimensions same way. Any way to fix this?
Front view of the pipe
Top view of the pipe
Pipe top view custom projection
Dimension is placed respecting original orientation, but not the custom one.
Solved by AIR_123. Go to Solution.
Solved by JDMather. Go to Solution.
You did not show screenshots of setting for True Dimension or Projected Dimensions.
Can you Attach your files here?
