Model opens in wrong view
sbromley
Message 1 of 9
sbromley
I have a few assembly models that do not open in the view I set as home, despite saving them as such.
One of them in particular opens zoomed into a part of the model and although not a hardship I have to click home to get it to show correctly.
Hoe do I get the model to open in the same orientation as I save it?
Autocad Mechanical 2023
Replies (8)
Message 2 of 9
JDMather
Have you installed all Service Packs and Updates?
Can you attach an assembly here that exhibits this behavior?
Message 3 of 9
mwighton
Are you saving the while in the home view?
Did this post help out? Hope it did.
If so please use the 'Accept as Solution' or 'Kudos' Button below.
God Bless
Mwighton
Message 4 of 9
sbromley
Nothing added but I have noticed that the xyz arrows bottom left are upside down. At some point I changed which view was "Top" so this has buggered stuff up.
Message 5 of 9
mwighton
When you change the view to your home view and save, make sure that the file is actually being saved. A view change doesn't register as a change, make sure that the file is selected 'yes' to save.
Try that and let me know what happens.
God Bless
Mwighton
Message 6 of 9
sbromley
I've got it to load in the correct viewing orientation but the xyz symbol is all over the place now. I'm going to leave it I haven't the time to spend. Thanks all. I'm afraid it's a case of a little knowledge is a dangerous thing in my case.
Message 7 of 9
Cadmanto
Just throwing this out there, but do any of these settings play a part in your issue?
check.PNGIf this solved your issue please mark this posting "Accept as Solution".
Or if you like something that was said and it was helpful, Kudoskudos.PNG are appreciated. Thanks!!!! Smiley Very Happy
Best Regards,
Scott McFadden
(Colossians 3:23-25)
Message 8 of 9
JDMather
@sbromley wrote:
I've got it to load in the correct viewing orientation but the xyz symbol is all over the place now....
You should have a Grounded part oriented to the coordinate system.
All of this is easy to fix - with an actual assembly rather than pretty pictures.
Message 9 of 9
sbromley
Yes, not something I know how to change.
