Mix-matched units in Parameters using exponets
Can someone help with this equation please. I am having trouble with mix matched units.
( ( ( 0.5 ul ) ^ ( MD * PI ) ) ^ 0.5 ul + ( PIPEOD ) ^ 0.5 ul ) * d17
d17        is unitless
PIPEOD   is inches
MD         is inches
Thank you for your help.
YannickEnrico
This should be usable:
isolate(Width;mm;ul)
Isolate(yourfunction;currentunit;expectedunit)
Edit:
Actually not sure if it works with an entire function, but then you can isolate the parameters separately
_______________________________________________________________________________________
Intel Core i9-14900KF
64 GB DDR5 6000 MHz
2TB WD_BLACK
RTX A4000
Inventor 2026 Professional
SBix26
Are you sure this equation is correct?  Written out in mathematical notation, it looks like this:
I can't make any sense of the units from this, so it's not too surprising that Inventor's math engine can't either.  What are you trying to calculate?
Sam B
Inventor Professional 2017.3.1
Vault Workgroup 2017.0.1
Windows 7 Enterprise 64-bit, SP1
Inventor Certified Professional
Thank you guys. Yes i wrote the equation wrong. It was late in the evening when was doing this. Thank you for answering and your input. I wrote it over after reading your post.
((((MD*PI)^(2 ul))+(PIPEOD^(2 ul)))^(0.5 ul))*TIGHTLOOPS
MD is in inches
pipeod is in inches
tightloops is unitless
