Inventor Forum
Missing Main Extrusion Dialog Box
6 REPLIES 6
3558 Views, 6 Replies
Every time I select Extrude from the ribbon I am only presented with the mini-toolbar. I have tried the solution of Alt+Space Bar, then M, then the arrow keys. How do I find the main dialog box? Thank you.
6 REPLIES 6
JDMather
Are you running dual monitors?
Have you changed monitor resolution or spread Inventor across monitors?
johnsonshiue
Could you take a snapshot of what you are seeing? Is is possible the dialog is in collapsed state (do you see a small horizontal bar saying Extrude)?
Thanks!
Software Test Engineer
in reply to: johnsonshiue
Thanks for the fast reply guys, I spent way too much time trying to find the solution myself. I am using two monitors, and I tried extending Inventor accross two screens as well as changing the resolution to no avail. However, I went back to one screen and sure enough there was the main dialog box in the corner of the screen.  I simply moved it to a more accessabile position. Now, after returning to two screens, I the main box is back. Thanks!
Curtis_Waguespack
Hi Hank_Venture,
If you have this issue in the future or with another dialog box, you can use this solution to get it back:
http://inventortrenches.blogspot.com/2011/01/missing-dialog-box.html
I hope this helps.
Curtis
I just got I MIGHT have rearranged my monitors.
Which was the deal, it simply wasn´t within the
visible area.
Changing the position, dragging the window, and
changing the monitors back again did it for me.
I think there should be an option to restore the
window positions...
Harrrrr
Daniel
Dogs aren´t flammable.
I had the same problem. it works now
Matt Wantz
Technology Administrators
