Missing data while converting to 3D pdf
Hi All,
I have attached two pictures.
I am using the factory design utilities. After adding the walls and doors in AutoCAD Architecture, I am not able to see the walls and doors in Inventor as solid (only as wireframe). Due to this when I convert the inventor file to 3D pdf, the doors and walls are missing.
Have a look at the pics.
Did anyone face a similar issue and can help me?
Thank you in advance
Regards
Naishal Thakker
Mark.Lancaster
@Anonymous
I haven't done a lot of testing with non-solid information to 3D PDF..  I know there was some issues in the beginning about missing items in 3D PDF, so make sure you have the latest updates for Inventor 2017 (assuming you are using 2017 and the 3D PDF).  Also I will tag @mdavis22569 and @mcgyvr for their input since they have dealt a lot with this feature.
Mark Lancaster
mdavis22569
Hi @Anonymous
Can you share the file with me?
As Mark mentioned you need to be on R3 for updates and using the newest templates that came out
Here is a link to the newest templates
https://knowledge.autodesk.com/support/inventor-products/downloads/caas/downloads/content/inventor-2017-language-packs.html#mtc-english
Mike Davis
