I have an assembly that i need to add a structural piece from the content center. However, when i open the content center, there is no content there. I have rebooted the computer and did a repair/ reinstall. Last time i used the content center, everything was there. There was an update that was applied to Inventor since the last time i used the conter center. Maybe there is an issue with the update?
Make sure you have not switch the Project as well.
From the description, it most like the library is not well set in project, try to check the state of library in project setting then.
Hope it helps!
Hi! Two places to check. Go to Tools -> Application Options -> Content Center -> where is the library definition folder. Is it set correctly?
Close all documents. Go to Get Started -> Project -> Configure Content Center (the button at the bottom on the right) -> make sure all available libraries are included in the active project.
Many thanks!
@Anonymous
One more thing to add. Make sure you don't have filters running in your place from CC dialog..
Mark Lancaster
& Autodesk Services MarketPlace Provider
