Inventor 2022:
Tried to use bolted connection & while the bolt standard I want to use is in the CC it is not available in the bolted connection designer.
Standard installed CC being used ie. no customisations.
Solved by b_woodorth. Go to Solution.
Sorted!
Thread size in the dialog needed to be set to a size available in the library. By default it is set at 6mm, & there are no 6mm bolts available in that particular library.
