Mirroring multiple parts in a multi body part and keeping position in assembly
eedmondsHRMXH
Message 1 of 9
eedmondsHRMXH
In a multibody part, I have these 3 parts highlighted. In the multibody, I mirrored them, but did not create a new solid as I want to mirror them in the assembly to re-use the primary part.
The LHS (highlighted) parts are grounded at origin - so they move and update with the master part. But the mirrored ones are grounded using assembly mirror function, so they do not update position with the multibody part, and I obviously can't ground them at origin because then they'll just be in the same position.
I do not want to delete the mirrored part then re-mirror the LHS parts, as that will probably mess up my drawings and it is a slow workflow.
How do I integrate this exact-same-part-in-a-different-position adaptability in my assembly from a multibody part?
I want to avoid creating new solids for all mirrors etc. - even though when converted to an assembly it will be adaptive. Surely there is a better way.
Replies (8)
Message 2 of 9
kacper.suchomski
Hi
Consider working on derived parts. They allow you to select bodies, as well as the direction of mirroring for individual cases (files).
Kacper Suchomski
YouTube - Inventor tutorials | WWW | LinkedIn | Instagram
Message 3 of 9
jtylerbc
Have the Multibody layout part in the assembly, and constrain the additional instances to it.
Message 4 of 9
eedmondsHRMXH
Hi Kacper,
I'm not really familiar with what you're saying. The parts in my assembly are derived from the master part?
Message 5 of 9
eedmondsHRMXH
I actually started to try doing this beforehand, but the workflow seemed slow, so I assumed there was another way.
Is this something you do?
Message 6 of 9
jtylerbc
Yes, this is what I do. My first choice, when possible, is to use feature patterns in the multibody and use an associative component pattern in the assembly to place the multiple instances.  When that doesn't apply, I constrain to the multibody.  Typically this is three Flush constraints to matching faces on the part and multibody.
"Seems slow" relative to what, exactly?  This is already a time-saving method vs. traditional manual constraints.  What faster method do you propose?
Message 7 of 9
johnsonshiue
Hi! The associative mirror component is something we have been working on. Please feel free to sign up Inventor Feedback Community (https://autode.sk/InventorBeta) and take a look at the workflow on the latest internal build.
Many thanks!
Software Test Engineer
Message 8 of 9
eedmondsHRMXH
Feature patterns is a good idea, I didn't think of this. That will work for some of my parts, however like you said it is sometimes not possible.
I don't have a method yet - that's why I asked the forum.
Thanks for the reply.
Message 9 of 9
eedmondsHRMXH
That's good to hear!
