Mirroring an Equation Curve?
DarkSapient
DarkSapient
I am getting a "Failed to create mirror" message when trying to mirror an equation curve about a line. Is there something I'm missing when creating the curve itself or is this functionality not yet supported? Thanks.
jhackney1972
If I am interpreting how you want to mirror, around the vertical center line, then the problem is the equation curve overlaps the mirror line.  I showed this with the red arrow.  If you place a mirror line past the end of the equation curve, you have no problem as you can see.  Modify your equation curve to not cross the vertical center line.
John Hackney, Retired
DarkSapient
I have tmin set to 0 and tmax set to 0.75. I'm not sure where those dotted lines are coming from or how to get rid of them. If I change tmin or tmax then I get an undesirable curve. I want to mirror the other equation curve also but I get the same error.
Edit: For some reason, the other curve will mirror now.
DarkSapient
Any idea yet on how to remove the dotted lines?
