Inventor: How to create a curved slot with variation in height
CAM-01-UMCINNOVATION
Message 1 of 9
Hi, I have this problem with that curved slot, 6.5 mm wide that I am gonna do with an 6 mm ballmill.
I had a similar part recently, where that slot was not curved and got it to work with the trace function, but this time it wont work. most of the passes that i can use on it have stepdown functions and therefore causing trouble when it comes to those various heights, leaving steps on the finished part, I cant find a way to get it smoothly following that contour.
model attached.
Thanks very much in advance
@CAM-01-UMCINNOVATION,
marius.gildehaus has edited your subject line for clarity
Original: Curved slot with variation in height
Replies (8)
Message 2 of 9
Xun.Zhang
Hello @CAM-01-UMCINNOVATION,
How about create a shared path with multiple circle profiles and sweep along the path.
Part is also enclosed and hope it helps!
Xun
Message 3 of 9
Hi Xun thanks for reply, yes i was thinking about something like this, if only i had some line to select and follow that as a contour, but i wouldnt know how to create such a line, my design skills on inventor are not as high, I use only the CAM side of it mostly, If you could send me that file through where you have been creating that line I could have a look how you did this, would that be possible ??
Message 4 of 9
Sorry, I just saw its attached already, my bad Smiley Surprised
Message 5 of 9
marius.gildehaus
Hello @CAM-01-UMCINNOVATION!
I see that you are visiting as a new member to the Inventor Forum. Welcome to the Autodesk Community!
Could the dataset and the explanation from @Xun.Zhang help you out?
If yes, please mark his post as his solution so other users can benefit from that.
Thanks!
Marius Gildehaus
Technical Sales Specialist
Message 6 of 9
I come to some problem in regards designing this 3d sketch on the part, I cant get it to work could you help me explain how you did it ? I can now use that Trace function on the line but its not following through, there seems to be some step in between the lines i have tried to alter.
thanks
Message 7 of 9
thanks
Message 8 of 9
leowarren34
When you miss an attatched fileSmiley Mad
We've all done it before.
Leo Warren
Autodesk Student Ambassador Diamond
Please accept as solution and give likes if applicable.
Message 9 of 9
marius.gildehaus
Please attach the part file and a Screencast so we can see the issue and help you out.
Otherwise we are just guessing and cannot provide the information you need.
Thanks!
Marius Gildehaus
