Inventor Forum
Mirror
4 REPLIES 4
johan.degreef
278 Views, 4 Replies
Mirror
I want to mirror the internal of this tank, so I have to model/constrain this only once. If I modify the originals side, I want the mirrored side to follow. Is this possible in Inventor? It should be, right?
I don't want grounded components on the mirrored side, because everey change i make in the original side make me do it all over again? Any tips? Many thanks.
Inventor 2025, Vault Professional 2025, Autocad Plant 3D 2025
4 REPLIES 4
mdavis22569
in reply to: johan.degreef
Why not derive mirror it?
Like this:
https://knowledge.autodesk.com/support/inventor/learn-explore/caas/CloudHelp/cloudhelp/2020/ENU/Inve...
Mike Davis
johan.degreef
in reply to: mdavis22569
OK, I will give it a try. Are the constrains mirrored also?
mdavis22569
Unfortunately no .. as everything is mirror to a different position in a sense. But it should be maintained in the main assembly and update as you update the original
Mike Davis
Hi Johan,
Did you use Mirror Components command? After that, you may need to tweak the constraints or create Symmetric constraints so the mirror side moves accordingly.
Many thanks!
Software Test Engineer
