MIRROR / PATTERN COMPONENTS
lkirit2000
Advisor Advisor
331 次查看
5 条回复
1 条消息(共 6 条)
lkirit2000
Please see the attached image below the components created mirror and patterns, but not constrained.
Do we need to constrain them ?
Rgds
Kiri
0 个赞
332 次查看
5 条回复
回复 (5)
2 条消息(共 6 条)
Xun.Zhang
Hello Kiri,
Where can I review the image? If I understand correctly, you are asking to constraint the whole bunch of components as original one, then, please check the option Mirror Relationships.
Pattern simply keep the relative relationships automatically, please let me know if it does not work for you.
Hope it helps!
Thanks.
Xun
3 条消息(共 6 条)
lkirit2000
Hi Xun,
Thanks for your response.  Yes I did as per your instruction, but Still not constrained.
Please see the image below.
0 个赞
4 条消息(共 6 条)
Xun.Zhang
OK, then, please user the second option Ground new components.
Hope it helps!
Xun
5 条消息(共 6 条)
lkirit2000
Hi
Thanks for your response. That's good idea.
I am not sure, if I modify the dimensions will it update automatically ?
Rgds
Kiri
0 个赞
6 条消息(共 6 条)
Xun.Zhang
Hi Kiri,
The short answer is no right now.
Please feel free to add your vote to the idea or another one which is similar as yours.
Thanks!
Xun
