Inventor 2015, Win7-64 and my middle mouse button doesn't pan. It does work as expected (universal scroll) in other programs so I know it's set to the right thing. Just doesn't seem to work in Inventor. Any ideas? It's a Logitech MX Revolution Bluetooth mouse.
Thanks!
Greg
Solved by admaiora. Go to Solution.
Hi Greg,
you will probably need to manually set and personalize the middle button with setpoit logitech software.
Set Middle Button to Middle Button
You can download Setpoint here:
http://www.logitech.com/en-gb/support/mx-revolution?crid=398&bit=64&osid=14
Admaiora
Thanks! I have that software, but misunderstood how the settings are setup. The setting that's for the middle button I thought was for the scroll wheel rotation, so I had that set to autoscroll. Figured out how to set it to middle button and now it works. Thanks again.
i am having the same issue. my middle scroll pan button stopped working and i don't know how to fix it. It is hard trying to work on drawings. Please help!
Hi! I am not aware of a systematic issue in Inventor causing the scroll wheel to fail. Could you update the mouse driver or change it to generic one? Is it possible the mouse scroll wheel is broken?
Many thanks!
