Metadata in features
bespel
Message 1 of 8
bespel
Hi, is it possibile to set data/description for a particoilar feature and recall it in the drawing?
Example:
I have 10 holes, all with same specs, but I would like to "name" each of these holes, es:
Hole1> K11
Hole2> K11A
Hole3> K11B
etc
Then I would like to recall these data in the drawing (position mounting references)
I would like to do that for holes but for features in general too.
DO you have any idea?  Thank you!
Replies (7)
Message 2 of 8
Xun.Zhang
Hi @bespel,
The Screencast plugin will allow you to capture a video of your work with command information in-context.
https://knowledge.autodesk.com/community/screencast
I hope this helps.
Xun
Message 3 of 8
bespel
Hi Xun,
thank you, but I don't need the Screencast .
The case is, (I hope) clear.
Otherwise, let me know.
Thanks!
Message 4 of 8
swalton
How about a 3D annotation in the model and then use the Retrieve Model Annotation command in the drawing?
I tried the Leader Text tool in a quick part model.  It seems to work ok.  I had to take care to make sure that the 3D annotation plane was parallel to the drawing view plane I planed to use.
Steve Walton
Inventor 2025
Vault Professional 2025
Message 5 of 8
bespel
Nice! Thank you!
So there are no alternative solution?
Message 6 of 8
SBix26
You can certainly change the name of each feature to be what you want (replace the name of Hole1 with K11B, for example).  But I don't know how to access these names in the annotations.
Sam B
Inventor Pro 2020.0.1 | Windows 7 SP1
LinkedIn
Message 7 of 8
johnsonshiue
Hi! This might be doable via iLogic rule but I am not 100% sure. In theory, you can rename the Hole feature to KA1 or something like that. Then add the feature name to a leader node.
Many thanks!
Software Test Engineer
Message 8 of 8
bespel
Great!
Someone has an example of this iLogic code?
Thanks!
