Ok, 'll look into that Blair, but.... I haven't touched this at all so far
since IV6.5
Something is different about IV11 measure tool, if I use measure distance,
why would it select a complete component or assembly? and if so, where on
that component/assembly whould it be measuring from?
Add to that, why does it occur sometimes and other times not?
It's these things which cause me to assume the feature is broke.
Derek
"Blair Stunder"
wrote in message
news:5417046@discussion.autodesk.com...
You might want to change the priority of the selection from assembly to part
or feature or face from the drop down menu on the main tool bar under
"Select".
Blair
"Derek Burns" wrote in message
news:5417028@discussion.autodesk.com...
I don't know about reliability of the measurement, but sometimes it just
plain doesn't work.
If you try to select a face, it selects and highlights the complete
part/subassembly.
A timely fix for this would be greatly appreciated, Autodesk.
Derek
"Blair Stunder" wrote in message
news:5416748@discussion.autodesk.com...
I have never had a problem, but you have to be carefull that you are not
measuring from what you think is the center or center line of a hole when in
fact you have selected the surface of a hole.
Blair
wrote in message news:5416544@discussion.autodesk.com...
Is the measurement tool in V11 now reliable?
