Measure tool panel missing
Ove.l
Message 1 of 33
Ove.l
Hello, when i try to use the measure comand i dont get the measure panel. I can still measure but only get the distance direct on the screen.
Per
Accepted solutions (4)
Replies (32)
Message 21 of 33
Thanks for your reply.
This only hides the measure button on the tools tab. The measure pannel is still missing.
Regards
Magnus
Message 22 of 33
Have you tried running the reset utility?
Message 23 of 33
No I have not. Which reset utility do you mean?
Message 24 of 33
johnsonshiue
Hi! Are you on dual monitors? Could the Measure tool be on the other monitor?
Many thanks!
Software Test Engineer
Message 25 of 33
The pannel dissapeared when I used the "Clean Screen" button. I am using dual monitors and I have tried the "Alt+Space" trick but it did not work unfortunately.
Message 26 of 33
There is an Inventor Reset Utility on the Start Menu under Inventor.Inventor Reset.jpg
Message 27 of 33
kelly.young
Autodesk Support
Autodesk Support
Hello @Anonymous I see that you are visiting as a new member to the Inventor Forum.
Welcome to the Autodesk Community!
You can either reset the ribbon:
Or run the Reset Utility.
You can read through this thread and see if anything in there helps:
Missing Top Line Panel/Menu, Hidden Ribbon Bar
Please select the Accept as Solution button if a post solves your issue or answers your question.
Message 28 of 33
Thank you. The reset utility solved the issue.
Message 29 of 33
Genicee
@Anonymous wrote:
Try this: Tools tab, right click the white space on the ribbon, show panels, check Measure.
This method seems to do the trick!
Message 30 of 33
Hello Dear friends
At the first step, press the CTRL Key + 0 keys
In the second step, right-click on the menu bar at the top of the screen and select Undock Ribbon then press the M key or Measure Tools ، you will see that the measurement panel appeared !
In the third step, right-click on the toolbar or top menu bar , and select the Ribbon appearance > reset Ribbon  option
Step Five, Enjoy!
Good Luck Engineers !
Message 31 of 33
Hello Dear friends
Step Five, Enjoy!
Message 32 of 33
Pete_Beau_Magna
This process worked in my 2020 Inventor. Also, export your 'options' settings so you can import them after this process.
Thank you for your help.
Pete
2020.2.2 Inventor
Windows 10 Pro
32 gb ram
AMD Radeon Pro WX 3200 video
Message 33 of 33
Thank you sir, I followed what you shared and it worked.
