Measure tool panel missing
Ove.l
Message 1 of 33
Ove.l
Hello, when i try to use the measure comand i dont get the measure panel. I can still measure but only get the distance direct on the screen.
Per
Accepted solutions (4)
Replies (32)
Message 2 of 33
Rob67ert
Looks like the measure window is off screen.
Do you use multiple screens?
Start the measure command and press "alt" "space" and then "m" (move depending on your OS language)
Then press and hold the left mouse button and move your mouse.
Robert
If you find this reply helpful ? It would be nice if you use the Accept as Solution or Kudos button below.
Message 3 of 33
Ove.l
I see what you meen, but it dont work on the measure command. If i try it on something else, like content center it works.
Per
Message 4 of 33
Rob67ert
Can you show what happens?
Robert
Message 5 of 33
Ove.l
This is how it looks when i try to use the measure command.
Message 6 of 33
Ove.l
I did a reinstall, it works now.
Per
Message 7 of 33
JoyceZhou
Hi Ove.l
It's great that reinstallation fix the issue.
And could you recall what action you had done before you saw the issue last time? This will help us reproduce the issue and find the root cause.
Joyce
Joyce-Jinghua Zhou
Inventor QA Engineer
Message 8 of 33
John_L_Hermosa
Hi, In Inventor 2018 it disappear once I put it on browser.
Then when I call the measure command, "it shows" in browser instantly but never come back again.
Please see the attach video.
Autodesk Inventor 2015 Certified Professional
Autodesk Factoty Design Suite Ultimate
Message 9 of 33
JoyceZhou
Hi John,
I see the issue now, but it's hard for me to reproduce it.
Could you try to restart Inventor and try again? I'm guessing it might relate with docking the Measure panel to the browser.
After restart Inventor, please invoke the Measure again and check whether you could see the Measure panel in the browser.
If you could see it, please try drag it out of the browser, then drag it back to the browser.
If you could reproduce the issue from scratch, it will help a lot.
Joyce-Jinghua Zhou
Message 10 of 33
Ove.l
Hello, i do not know what i did do when it happend. I can drag it the from the ribbon and put it back now without problem.
Per
Message 11 of 33
tasdemt
Hi Ove.I,
There is a solution without re-installing Autodesk Inventor. Please follow these steps;
1. Please, Go to Windows Start Panel and search for Regedit then open it
2. Please, Go to HKEY_CURRENT_USER folder and open it
3.Please, Go to AUTODESK folder and open it
4.Please, Go to Inventor folder and delete it
5. Please, Then close Regedit and open Inventor finally try Measure command.
It should work.
By the way, please don't move, delete or do any other operation on other folder at the out of HKEY_CURRENT_USER.
I hope these helps.
Timucin
Timucin E. Tasdemir
Technical Sales Specialist, Turkey
Design and Manufacturing
Autodesk, Inc.
Message 12 of 33
John_L_Hermosa
Hi, tasdemt.
This works for me.
Thanks!
Message 13 of 33
If you are still looking for a/the source of this issue, one of our engineers used the "Clean Screen" view function, and lost the dialogue box, and another engineer confirmed this causes the box to disappear when this was being discussed soon afterwards. The registry entry deletion resolved the issue and brought it back.
Cheers
Kade
Message 14 of 33
That's right!
Following steps solve it.
Thank you!
Message 15 of 33
I've tried this method and it works however when I now open a model the visual style keeps defaulting to shaded instead of the shaded with edges? Can this be resolved?
Message 16 of 33
You can choose the visual style of a model. It's possible in Display Appearance (Tools / Aplication Options / Settings).
You should apply your preferences (shaded with edges) and enable "Use application settings" button.
The pictures below show the configurations mentioned.
It should works.
Message 17 of 33
Aldred
Hi Everyone,
If you delete this registry entry does it reset any customised settings like the inventor reset utility?
Aldred
Message 18 of 33
It work.
Thanks for your help.
Best regard - JS
Message 19 of 33
Hi
I have the same problem, but I use a remote desktop so I am not able to access the registery.
Is there another way to get the tab to reappear?
Regards
Magnus
Message 20 of 33
Try this: Tools tab, right click the white space on the ribbon, show panels, check Measure.
