Message 1 of 20
materials densities are incorrect in inventor 2020
07:27 AM
I have a similar problem in Inventor with material density.
When I pick a shape from Content Center, this program set the material to Steel, Mild. When I check the weight of assembly, i realise this value is wrong. Then I open a shape and check the wight. I see the density is 1.000 g/cm^3.
I can't change the base material. It is important for me, this standar material would be correct. Naturally I can change it in BOM, but i would like to set the base material correct.
The second way I change the base material, but i can't change the material of Content Center elements.
Please help me!
