Inventor Forum
Master View in an Assembly
6 REPLIES 6
shastu
1095 Views, 6 Replies
shastu
Can someone please explain to me what the Mater View in an Assembly is used for? If the Master View is always locked and you can't unlock it, which means you can't save any changes to it, then why do I ever need it?
6 REPLIES 6
CCarreiras
in reply to: shastu
CCarreiras
Because in the Master view, you can know, without any doubt, what is in the main assembly.... that's why you can't edit or delete.
If you wanna check all you have in the assembly, with no mistakes, no doubts.... go to Master view!!!
CCarreiras
CCarreiras
in reply to: shastu
You CAN save while in the Master Design View.
It will save any modelling changes you've made; just won't save view changes, e.g. section views, visibility, etc.
karthur1
in reply to: CCarreiras
karthur1
Well, in theory, yes, that is the way that it is supposed to work.  But, in 2016 I have been having issues with any view rep.  Sometimes the Master does not show ALL things.
Kirk
Kirk
CCarreiras
in reply to: karthur1
CCarreiras
Hi!
ok... but this because it's working bad. If you found a bug... it's better report it.
CCarreiras
Hi!
CCarreiras
salariua
in reply to: shastu
salariua
I don't use it at all. I have edited my template.iam and I have added another design view "Default" that is not locked and it's set as active before save so each new assembly starts with "Default" on.
Adrian S.
blog.ads-sol.com
AIP2012-2020 i7 6700k AMD R9 370
Did you find this reply helpful ?
If so please use the Accepted Solutions or Like button - Thank you!
Adrian S.
blog.ads-sol.com
in reply to: salariua
Great work-around for a stupid feature.
