Inventor Forum
Mass of machined part in BOM
11 REPLIES 11
Message 1 of 12
lasercrafty3d
403 Views, 11 Replies
I have parts in an assembly edited with assembly features and cut extrusions. When I'm trying of get the final mass in BOM (mass column) apear the value of original part file. Is the same with the custom parameter of area (=<surfacearea>), but when I check the iProperties, the mass and area are of the edited part. Can you helpe to obtain the final mass and area of the edited parts in assembly?
11 REPLIES 11
Message 2 of 12
i believe the value you are looking for doesn't exist. if you are making an edit in the assembly level, say cutting away material then that won't be accounted for in the part, as that change is happening at the assembly level.
are you looking to edit the part for a specific reason?
or is the end goal to change the part at the assembly level based on the design need?
Message 3 of 12
My objetive is adapt the part to the specific asembly. The original part change by design and the asembly is based on an specific segment of that part. I need obtain in the BOM for my Bill of Materials the mass of the final segment of part to obtain cost.
Message 4 of 12
i understand what you are looking for, but if you are altering the part at the assembly level, there is no way inventor can calculate what the new part is based on that change. The inventor part file is only going to reflect the mass, as how the part is saved.
it has no way of knowing what the mass of a part is once its changed outside of the part enviroment.
Message 5 of 12
The mass of the final piece appear in the iProperties Physical section, but in the mass properties appear the original mass of file part. Is there a way to obtain the final mass of physical section in a field in BOM?
Message 6 of 12
my understanding is that the mass shown in the BOM reflects the mass in the part file, not as it appears inside the assembly, i recreated your example and i'm working to find a way to get the BOM to show that particular mass. the issue is that inventor sees those parts as the same part, because they are essentially the same file.
Message 7 of 12
even when i add a custom iproperty that is mapped to Mass, it does not show the value when the Mass has been altered in the assembly level.
Message 8 of 12
blandb
in reply to: lasercrafty3d
Can you utilize the copy object command to bring in the component you need to cut out as a surface, then your part will reflect the cut mass?
See if the attached video helps?
Autodesk Certified Professional
Message 9 of 12
AndrewHumiston
in reply to: blandb
the issue still is that there are 2 parts in the BOM with the same part number and meta data, just a different mass, inventor needs to know to split them to two rows as well as pull the mass data for each one seperatly.
Message 10 of 12
lasercrafty3d
in reply to: blandb
There are tousand of pieces in this condition. Is there a way to put an instance property with thw iProperties Physic value showed in the asembly? Tis one?:
Message 11 of 12
 Tried the instance iproperty and couldn't pull the mass up to that level, it is setup for custom properties
Message 12 of 12
A.Acheson
in reply to: AndrewHumiston
You will need to take the assembly level mass as this is where the machining is happening after the parts are created. So either put the part into a sub assembly weldment /assembly and track the machining, labour, mass change etc here. Or alternately make a model state part for part before machining and afterwards and give it separate part numbers.
Regards
Alan
