I have an .ipt with several model states to represent a purchased component family. They're different sized cabinets with different "guts". I'm only trying to represent the externals (for now) and don't want to spend the time modeling the internal components. The calculated mass is off because of the missing internal components. I would like to manually override the mass for each model state, but the mass override isn't part of the model state spreadsheet.
I've thought about turning this into an iPart factory (don't know yet if that would work any better), but was hoping to stick with model states because for me they work better when automating our product line. The only other thought I've had is to model a block in the cabinet and change it's size to force the calculated mass to the actual mass.
Does anyone know a way to have different mass overrides for each model state?
INV Pro 2024
A long way.
Create material with different density that give you correct mass.
Thanks for the idea but I'm going to hard pass on that. Some of the cabinets are the same size but different weights. 56 lbs. and 197 lbs. in the same size cabinet. I'd have to have a custom material for each part number... I'd rather spend the time perfectly modeling the interiors😋 at least that would add value to the model.
Hi! Another quick way to do that is to create a custom iProperty, replacing the physical iProperty mass. When you need to show the mass, make sure you reference the custom iProperty, not the iProperty mass.
Many thanks!
Would that still calculate the correct mass for an assembly that contains my part?
I submitted an idea at the link below.
https://forums.autodesk.com/t5/inventor-ideas/mass-override-for-each-model-state/idi-p/12228420
