I simulating a part where I can achieve convergence by manually refining the mesh element size. However, while using the automatic function using convergence settings, I can't achieve a similar result. The calculated stress just keeps increasing. Does anyone know what could be causing this?
best regards,
George
best regards,
George
CAD and PLM admin | My ideas | Inventor-Vault Expert GPT (my AI brain)
I believe it is something with the geometry but I'm not sure what the best way to address it is. Any tips would be welcome! I've attached the model for reference.
Hi! Another possibility is that there is bad geometry. Go to the Modeling environment -> press Ctrl+F7. Does it report any bad body? If yes, please run through Repair Bodies workflow to fix the bad geometry.
Another possibility is that there is too much detailed geometry. Try using Delete Face -> Heal to remove unneeded detail geometry.
Many thanks!
Many thanks!
