Inventor Forum
Making Weld lines invisible on idw's
4 REPLIES 4
MikeKovacik4928
776 Views, 4 Replies
Hi All
The orthographic views of a weldment in an idw is usually very messy - lots of lines representing the weld,
and mixed with the lines representing the edges of the object itself, tends to make the drawing difficult to read.
Is there a way of turning off the welds in chosen idw views?
Michael Kovacik
Inventor Pro 2020
Vault Pro 2020
South Africa
4 REPLIES 4
Cadmanto
in reply to: MikeKovacik4928
@MikeKovacik4928
See if the attached link works for you.
https://forums.autodesk.com/t5/inventor-forum/how-do-i-hide-weld-features-in-drawing-views/td-p/8350...
Windows 10 x64 -16GB Ram
Intel i7-6700 @ 3.41ghz
nVidia GTS 250 - 1 GB
Inventor Pro 2021
Best Regards,
Scott McFadden
(Colossians 3:23-25)
Hi! On top of the approach mentioned by Scott, you can simply create a Design View Rep and turn of the Weldment visibility. Make sure the drawing view is linked to the DVR.
Many thanks!
Software Test Engineer
MikeKovacik4928
in reply to: Cadmanto
I accept that as a solution, unfortunately the "accept as solution" button has vanished.
It worked in my particular case 1 (an assembly that only had parts inside it), but in another particular case 2 it didn't, the dialogue box was greyed out (an assembly that had a derived part and a sub assembly inside it).
Case 2 was the one I really wanted to do it in, Case 2 was the assembly with Case 1 inside plus the derived part.
How would I get it to work in Case 2 or get the dialogue box ungreyed out.
IQ_202_Making Weld lines invisible on idw's_001.jpgIQ_202_Making Weld lines invisible on idw's_002.jpg
Michael Kovacik
Inventor 2020 pro
South Africa
Cadmanto
@MikeKovacik4928
Is the view associative to another view that is controlling this one?
If so, uncheck that box to disconnect and allow control.
Inventor Pro 2021
Best Regards,
Scott McFadden
