Hi All
The orthographic views of a weldment in an idw is usually very messy - lots of lines representing the weld,
and mixed with the lines representing the edges of the object itself, tends to make the drawing difficult to read.
Is there a way of turning off the welds in chosen idw views?
Michael Kovacik
Inventor Pro 2020
Vault Pro 2020
South Africa
Solved by johnsonshiue. Go to Solution.
Solved by Cadmanto. Go to Solution.
See if the attached link works for you.
Windows 10 x64 -16GB Ram
Intel i7-6700 @ 3.41ghz
nVidia GTS 250 - 1 GB
Inventor Pro 2021
Hi! On top of the approach mentioned by Scott, you can simply create a Design View Rep and turn of the Weldment visibility. Make sure the drawing view is linked to the DVR.
Many thanks!
I accept that as a solution, unfortunately the "accept as solution" button has vanished.
It worked in my particular case 1 (an assembly that only had parts inside it), but in another particular case 2 it didn't, the dialogue box was greyed out (an assembly that had a derived part and a sub assembly inside it).
Case 2 was the one I really wanted to do it in, Case 2 was the assembly with Case 1 inside plus the derived part.
How would I get it to work in Case 2 or get the dialogue box ungreyed out.
Michael Kovacik
Inventor 2020 pro
South Africa
Is the view associative to another view that is controlling this one?
If so, uncheck that box to disconnect and allow control.
Inventor Pro 2021
