You can change the bom reference of a regular part/assembly in the browser tree under button Bom structure to reference in order to reduce the qty in the BOM. The graphics will still show. In the drawing the part will appear with dashed lines as standard. This can be changed in the view settings.
A few ways to change qty of virtual parts.
- Create more occurrences in the assembly and ensure they have matching part number.
- Pattern virtual parts
- Overwrite the qty in the BOM.
- Use ilogic to overwrite the qty in the BOM
ThisBOM.OverrideQuantity("Model Data", "OccurrenceName", "300")
Hopefully this will answer your question. If not please post back with some images of your intended workflow.
If this solved a problem, please click (accept) as solution.
Or if this helped you, please, click (like)
Regards
Alan
