Message 1 of 19
- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
- Report
I am using the 'make components' to export some parts from a multi-solid body.
The part is in inches and scaled wrong, so I'm also using the scale option to correct the part size.
This is where the problem exists.
The part is a wheel, it has a diameter of 6350mm (should be 250mm)
When I scale it by 1/25.4 the resulting part comes out at 247.65mm
I tried 1/25.3 to se what happened and the result was 254mm
It seems this feature is limited to 3 decimal places for accuracy.
When I use 1/25.4 it rounds to 0.039, when I use 1/25.3 it rounds to 0.040.
Is there a setting somewhere I'm missing, or is this a bug to be fixed by Autodesk?
Paul.
