Machined Sub-Components not Appearing Correctly in Dwg
- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
- Report
Hello, I have an issue with machined components appearing correctly in an upper level drawing.
I have an assembly that has machining steps done to it. This assembly is then inserted into an upper level assembly where final welding is completed. When I begin detailing the upper level assembly, this sub-assembly's machining details don't appear in the views in the .dwg. If however, I change the view to Raster the machined details appear correctly. Exporting the drawing to pdf when the view is in Raster cause errors in the pdf, so I can't leave them in raster form.
Has anyone encountered this issue or is there a simple solution I am missing? See the images below for the issue I'm seeing. Raster view shows the machining details, and normal view does not.
-Dave
