All menu settings/changes are saved apon a proper exit/close of IV. Export
as directed, or make changes, then close before you open a IPT, IAM or IDW.
AIP 2009 sp1 Bonus Tools
Dell Precision 690
Dual Quad Core E5320 @ 1.86GHz
4Gb DDR SDRam - 667 Mhz, ECC
SAS 146Gb - 15k rpm
Quadro FX3500 256Mb - Driver: 178.26 Bios: 5.71.22.55.08
Direct 3D
XP Pro Sp3 3Gb/2800
Space Explorer USB, release: 3.6.10 driver 6.6.4 firmware 3.17
"Duncan Anderson"
wrote in message news:6074246@discussion.autodesk.com...
As a temporary solution Export the Application Settings, then Import them to
recover your settings.
Duncan
"Humour ... is one man shouting gibberish in the face of authority, and
proving by fabricated insanity that nothing could be as mad as what passes
for ordinary living."
(Terence 'Spike' Milligan K.B.E., 1918-2002)
www.autodesk.co.uk/inventorjobs
http://support.microsoft.com/default.aspx/kb/555375
wrote in message news:6074189@discussion.autodesk.com...
Everytime Inventor crashes or I shut down I have to set all my menu's back
up. That includes dragging Macro's back on and setting enviroment back up in
menu's customize. This happens on one computer of 40 setup close to
identical...ideas? Thanks
