Looking for this exact wood texture!
Beyondforce
Advisor Advisor
Message 1 of 14
Beyondforce
Hi Guys,
I'm looking for this exact wood texture for Inventor (see attachment). I hope someone can tell me where can I find it. I have searched the network for so long but nothing! 😞
Thanks.
Beyongforce
Ben Korez
Fusion 360 NewbiesPlus
Fusion 360 Hardware Benchmark
| YouTube
Replies (13)
Message 2 of 14
mcgyvr
Google images "light wood texture" "zebra wood texture"
"striped wood texture"
Message 3 of 14
JDMather
Check the links from this page http://www.cbliss.com/inventor/Textures/
the noctua link usually has some good textures.
Message 4 of 14
Beyondforce
I have found similar to those 2, but I can't make them look like the one in the attachment.
Maybe it's a photo of a real wood and not an Inventor wood texture.
Ben Korez
| YouTube
Message 5 of 14
LT.Rusty
If I had to guess, I'd say that image probably wasn't done in Inventor at all.  The image pretty clearly shows plywood, and Inventor will not give you a good  clean plywood effect like that without a lot of really careful, time consuming and annoying messing around.  It'd be a lot quicker and simpler to get something like that out of 3DS Max instead, and that's what I suspect that the ADSK marketing types did.
Rusty
Message 6 of 14
Beyondforce
Rusty,
Thanks, I thought so too. I'll try to figure out something.
Thanks everyone 🙂
Ben Korez
| YouTube
Message 7 of 14
JDMather
Years ago - this used to be pretty easy in Inventor - then they changed everything and I haven't used textures since.
Never took the time to figure out the new way.
Message 8 of 14
LT.Rusty
Yep.
Anymore if I need to do something like what's shown there I'll just send it over to Showcase.  Designate the front and back of the wood as one texture, designate the edges as another, then do it all with GIMP and Showcase.
Rusty
Message 9 of 14
mflayler
cgtextures.com is a pretty good place to look for these too.
Mark Flayler - Engagement Engineer
IMAGINiT Manufacturing Solutions Blog: https://resources.imaginit.com/manufacturing-solutions-blog
Message 10 of 14
Beyondforce
Hi Mark_Flayer,
Thanks, I know this website. But I think LT.Rusty is right. The best way for me to get the texture to work, is by using Showcast. Inventor is too complicated in regards to adding new textures and the result is not good enough.
I have found some textures, we'll see if I can make it work.
Thanks 🙂
Ben Korez
| YouTube
Message 11 of 14
mpatchus
Take a look at Wood Workshop from Sprial Graphics.
http://www.spiralgraphics.biz/ww_overview.htm
I've used it to create many seamless wood textures for Inventor 2012.
We haven't advanced beyond 2012, so I don't know if it as useful for later releases of Inventor.
Mike Patchus - Lancaster SC
Inventor 2025 Beta
Alienware m17, Intel(R) Core(TM) i9-10980HK CPU @ 2.40GHz 3.10 GHz, Win 11, 64gb RAM, NVIDIA GeForce RTX 2080 Super
Did you find this reply helpful ? If so please use the Accept as Solution or Kudos button below. 🙂
Message 12 of 14
-niels-
Not sure if that exact texture is in there, or if the directory is available since it might be part of the suite install, but see if you have this directory:
C:\Program Files (x86)\Common Files\Autodesk Shared\Materials\Textures\3\Mats
There's a lot of nice textures in there, directory "3" seems to hold the "high res" versions.
Niels van der Veer
Inventor professional user & 3DS Max enthusiast
Vault professional user/manager
The Netherlands
Message 13 of 14
Beyondforce
Hi mpatchus,
Interesting program, I'll check it out.
Thanks 🙂
Ben Korez
| YouTube
Message 14 of 14
Beyondforce
Hi niels,
I have checked this directory, but I couldn't find what I was looking for.
Thanks.
Ben Korez
| YouTube
