Looking for ideas on building a part library
- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
- Report
I've been fighting with getting some components built as some kind of library setup for a while, but have essentially hit a wall and was hoping to hear other peoples' input/experiences. We'll see if I can organize this in a cohesive way.
Goal is to create some sort of library for paint fittings we frequently use
Why:
- To be able to easily insert parts that are well-defined
- To be able to swap out fittings in-place, primarily for size changes
- To have useful descriptions/stock numbers/BOM callouts on said parts
- To have accurate geometry on parts, due to space constraints we typically deal with
- To stop messing up these fittings because of the number of details to juggle and mistakes that slip in
What I have:
- Solid body files from the manufacturer
- These files do not encompass all products though, but everything can essentially be broken down into smaller components and reassembled into different products
- Some products with different part numbers are actually identical, primarily fittings for some sizes of metric and standard tube. In these cases, I would want to insert them as the 'actual' part, but simplify ordering by getting the 'standard' part
What I have tried:
Dumping imported fittings into a folder, opening them and applying tweaks for usability
- Fairly time-consuming
- Becomes an absolute mess if a tweak is wrong or needs to be changed
- Does not help for products without models
- Absolute nightmare swapping fittings out in other assemblies (ie. Changing hose size, making a metric version, etc), as all constraints + tube and pipe will completely break
Making one table-driven 'Master' part
- Seemed like a good idea, was a convoluted nightmare
- Then tried to incorporate different fitting types, which did not go well. At all
Making several table-driven 'Master' parts
- Resulted in several convoluted nightmares
- Updating/tweaking/adding new entries in them has become a lesson in futility
Turning the smaller components into iFeatures
- Could re-use identical features in different table-driven parts
- However, iFeatures would always break and become unusable once the part got more complex, which I spent ages try to find the cause of but never could
Currently I'm bouncing around the idea of making table-driven parts out of the sub-components, as well as a table-driven 'frame' part to have some fixed work points/axes/planes for the sub-components to be constrained to.
That should allow me to re-use the sub-components more effectively, though with them being an assembly I won't be able to fully utilize the content center for them
Addendum: The earlier-mentioned tweaks I make to the parts
- Set proper part number, stock number, material, etc to the parts
- Apply a color-override to the fittings (Does not work with table-driven things unfortunately), basically I'll change the colors of the threads, Red for NPT, Blue for NPS, Green for BSPT, and use different shades for each size
- Add iMates at appropriate locations, often having to slice the modeled threads with a workplane
- For the iMates, add names as well as an offset to ensure that only matching iMates can physically be attached to each other (ie. 3/8" NPT fittings get a 0.003751 offset, 3/8" NPS get a 0.003752 offset, and Inventor does not allow iMates to attach if they have different offsets)
