Triangle with a curved edge
Can anyone teach me how to create this triangle? I've attached the image. Thanks for the help!
andrewdroth
That's called a lug.
You can make it like this.
Andrew Roth
rothmech.com
YouTube IconLinkedIn Icon
IV2025 Pro
Apple IIe Workstation
65C02 1.023 MHz, 64 KB RAM
Apple DOS 3.3
leowarren34
The drawing lacks details but interpreted it 50 for the inner and 50 more than the inner for final edge
Heres a quick render:
Essentially follow the dimensions, then for the round do a 50mm and a 100mm concentric, with a centre 240mm above the base line. Draw lines from each side then set tangential to circle and trim. Then extrude.
Leo Warren
Autodesk Student Ambassador Diamond
Please accept as solution and give likes if applicable.
Thank you very much Andrewdroth!
