longer flange
longer flange
longer flange
hi im creating a sheet metal part, but my flanges need to be longer than the part, what is the best way to achieve this
thanks
JDMather
Can you attach what you have completed so far and indicate the required dimensions?
my problem being is that i need to create a part like this, but with corner round
on all 8 of the top and bottom and at the minute can only get 4 done
cheers
Curtis_Waguespack
Hi richyrich0000,
Attached is a quick Inventor 2015 example showing one method you can use.
I hope this helps.
Curtis
JDMather
See attached (I changed your Sketch3 and Cut1).
