Inventor Forum
logarithmic spacing
1 REPLY 1
nwk23
498 Views, 1 Reply
logarithmic spacing
I want to create an array where the elements are space logarithmically.  Is that possible?
I'm basically making a custom slide rule where the markings will be CNCed.
1 REPLY 1
johnsonshiue
in reply to: nwk23
Hi! You will need to do that by using sketch-based pattern. You need to create points (2D or 3D). Then the spacing is driven by equations in parameter expression. Lastly, pattern the feature based on the points.
Many thanks!
Software Test Engineer
Technology Administrators
