Lofting error
Lofting error
Lofting error
Can't perform loft in selected file. Loft joins the 2 separate bodies.
Error message:
Create loft feature failed
Fuel input.ipt: Errors occurred during update
Loft3: Could not build this Loft
The attempted operation had problems trimming and discarding faces. Try with different inputs.
Check if the attached model meets your requirements. I lofted as surfaces then stitched them together to make the solid between the bodies.
TheCADWhisperer
I used a slightly different technique than Ken.
I was able to perform the loft this way, thanks!
By the way, any reason why i could not do a regular loft?
TheCADWhisperer
This doesn't look manufacturable to me?
Is there a reason your wall thickness is all over the place?
I think I would model quite differently, but not really sure of your design intent.
