Loft Creation error
Loft Creation error
veenal.datt
Loft Creation error
veenal.datt
I am trying to loft 4 geometries as attached with 3d lines intersecting all of them.
Cannot seem to execute this. Any help would be appreciated. Thanks
kacper.suchomski
Hi
The guide cannot be construction.
You need to add a bottom guide.
This can be done in segments.
Kacper Suchomski
veenal.datt
Ok I think I tried what you asked for. As a result below which again had issues
kacper.suchomski
I also wrote to do it one by one in segments.
Kacper Suchomski
WHolzwarth
As already mentioned by Kacper, lofting from section to section is best.
Here's a solution with some cleanups in loft transition lines (2024 IPT). I can do it in 2021, if needed.
Walter Holzwarth
veenal.datt
Thank you for help. Sorry ingored that bit. It works well
