Avoid markering hidden lines when sketch on a face
almogA2PPB
almogA2PPB
Hey,
I have a profile, frame to be precise, and I want to sketch something on one of its face (file attached). When I sketch on the face the cursor always snaps and marks hidden lines, and its disturbing. Here is an image demonstate one hidden line that marked because I passed with the cursor on it. Im looking for option, if there is any, to eliminate any interaction with hidden lines (ones that not on the sketched face).
Thank you!
Gabriel_Watson
I could not find any setting to disable this, so the best workaround might be in the View tab > Half section view to temporarily hide the rest of the part behind (use a very small slice distance).
blandb
Do you have this option checked? If so, uncheck it and see if it improves:
Autodesk Certified Professional
