- Mute
- Permalink
- Report
Hi all,
I am using the Loft command as it is the most appropriate option in a work project I am trying to complete.
Firstly, I have created several planes offset at various distances through Autodesk Inventor.
Is it possible to copy and paste AutoCad drawing detail to each individual plane or do you have to draw each detail on each plane?
Then, the plan is to use the loft command and connected each plane detail along a path to create a solid structure.
I am trying to create a hull of a ship, each frame will be added to each offset plane beginning with the stern or back of the ship along a path to the bow or end frame of the ship.
My query is, rather than drawing each frame detail for every plane, is it possible to copy and paste an AutoCad drawing detail into this Inventor process.
I am trying see if it is possible to create the hull design using this method. Most of the frames details are the same size and reduce in size and shape as it develops to the front of the hull shape.
Anyone with experience of same that is able to offer any suggestions or advice will be welcome.
Niall
